Discussion topic: No terrestial tv
Message posted on 12 Jun 2025 09:26 PM
No terrestial tv
I'm unable to obtain any terrestial tv and obtain a message saying "there is a technical fault. Please try later. It has been like this all dat. I can obtain I player and Netflix they are working fine. Anyone else having the same problem?
Message posted on 12 Jun 2025 09:51 PM
Re: No terrestial tv
@Enrico1 If they are telling you it's a technical fault then that is what it is! Try it later it may just be fixed sometime! try looking on the correct Forum you may get a better idea.
Message posted on 09 Dec 2025 02:30 PM
Message posted on 09 Dec 2025 02:44 PM
@Zxanadu12 Have to don the following to see?
If you haven’t done it already use the below link to check to see if there are any broadband problems or outages nearby if enough time has passed for a fault condition to be displayed by the software test! This should determine if there's an identified fault affecting multiple households.
