Discussion topic: No sky
This message was authored by: paulallaway
No sky
We have no sky
Re: No sky
@paulallaway wrote:
We have no sky
@paulallaway
As you've posted on the Broadband board presumably you mean no Sky broadband?
The first thing to try (even if you’ve already tried it) is to use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
