Discussion topic: No signal
This message was authored by: Peter384
No signal
Streaming tv and all of a sudden no signal. Devices can still see the router but there is no signal, opened unit is red on LOS LED
Re: No signal
@Peter384
As you have Sky Fibre and your ONT shows a red light then have a read of this:
If nothing there helps then the first thing to check is this link to see if there are any outages in your area, it can be a bit slow at picking up issues so if nothing shows perhaps try it again later:
If there isn't try running the line test here:
