Discussion topic: Full fibee
This message was authored by: Philipge89
Message posted on 21 Jul 2026 10:20 PM
Full fibee
City fibre came this morning to fit stuff for an upgrade. Now the broadband and WiFi are very poor. My Sky says issue with streaming, but it seems to be working.
Find out more
Message posted on 21 Jul 2026 10:21 PM
Re: Full fibee
A poor signal in certain rooms is something that can cause this so try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will loan up to 3 pods as you can read about here:
So you can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on the above link.
