Discussion topic: No phone
This message was authored by Plur This message was authored by: Plur
No phone
Have internet but no Wi-Fi calling have reset my route to multiple times I think I need the Sky engineer to come out to my home address again
Re: No phone
@Plur its not 100% clear what you mean. If you are talking about wifi calling over your mobile that is controlled by your network provider not Sky broadband so resetting your hub will achieve nothing.
If however you are talking about the landline provision via your hub then call Sky to report the fault.
This message was authored by Kal2001 This message was authored by: Kal2001
Re: No phone
@Plur Need more context! Is it the Landline you are referring to? If so, do you have internet calls in your package otherwise known as VoIP? If you do have internet calls make sure the phone port is connected from the back of your phone to the back port of your hub labelled as UK with a phone icon.
This message was authored by shirley1964 This message was authored by: shirley1964
Re: No phone
Had a storm 3 days ago had no phone working....unplugged it and my Internet and tele but landlines is not connected
Re: No phone
@shirley1964 Might have been an outage, and there could be something wrong with the exchange outside. May need to contact sky and request them to run a test and see if you need a Openreach engineer
