Discussion topic: No network connection broadband
Message posted on 21 Apr 2025 10:09 AM
My tv's are showing no network connection
Message posted on 21 Apr 2025 10:58 AM
Re: No network connection broadband
Are they sky glass tvs if so try turning them off for a few minutes by unplugging them from the mains and then when plugging them back in push and hold the power button in on the side of the tv, also how are your tvs connected to the Internet, if you can try connecting them with an ethernet cable as that is a more stable connection, i have both my 55inch sky glass tvs connected this way and i have no problems, but i am also on sky gigafast broadband 900mps which is full fibre to the property hope this helps you
Message posted on 21 Apr 2025 11:01 AM
Also have tried turning off the hub and restarting it, and have you used the my sky app to run a service check on the Internet to see if there is an issue on the line
Message posted on 21 Apr 2025 05:25 PM
I'm having the exact same issue, have tried all the troubleshooting and still nothing
