Discussion topic: No master phone socket
This message was authored by: TD93
I have moved into a council property and there seems to be no master phone socket! What do I do? Do I need this for sky wifi? Appreciate any advice as I'm clueless, unfortunately!
Re: No master phone socket
@TD93 Check the link to see what sky can supply to the home!
https://www.sky.com/broadband/full-fibre-broadband
or the btw site below just use the address if the one above does not show!
BT Broadband
@TD93 If there is no Openreach/City Fibre  line Sky can probably arrange to have one fitted but check with the council if they still own the property as they will need to give permission before the work is done.
