Discussion topic: No lights on for internet
This message was authored by: JazAndAsh
Internet / WiFi was working completely fine until around 10.30am this morning, when the internet completely dipped out.
I have followed all the steps as suggested by Sky; the tests suggested it was an issue with router / connecting that way. I have pulled all suggested wires out and reconnected as suggested, done resets, turned on and off at all the wall etc - still no light on for 'Internet'.
Apparently no issues with WiFi / broadband according to Service Checker?
I am trying to work from home, and urgently need it fixed! 😞
I have not had any issues so far, but the box is only a few months old if that.
Is there not a telephone line I can call for further help? Thanks so much for any advice in advance.
Re: No lights on for internet
First thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
The Service Checker doesn’t necessarily disclose a problem immediately and there is up to an hours delay before it picks up a lost connection so perhaps try it again later.
Sky broadband being discussed here is a domestic service and whilst it's fine for those customers working from home to use it, they won’t receive additional or quicker support.
If it's still working dial 150 free from your Sky Talk landline.
Avatar for JazAndAsh
Thanks for clarifying. Unfortunately, there have been no changes here as time has passed. Everything is pointing to an issue with how my hub is connected, but despite repeatedly following the suggested steps, there have been no changes. It was also working fine and was not tampered with or touched prior to the sudden internet drop.
I was not suggesting that I was entitled to additional or quicker support; I was outlining my situation to provide further context to how it was functioning well previously, and to highlight that it would have been of great benefit to have the issue resolved (which sadly it has not been, 4 days later and going into a bank holiday weekend☹️).
I do not have a landline. I am surprised that a company such as Sky does not have an easily accessible support helpline for those without a landline.
@JazAndAsh
You do have a Sky Talk landline as it's bundled with your broadband package but you have chosen not to connect an actual handset which is fine and entirely your choice.
In the future if you have a cheap handset you only need to plug it in when you need to call Sky (dialling 150 free) if and when there's an issue.
