Discussion topic: No internet or sky
This message was authored by: MariaG100
No internet or sky
Sky is not working and also my devices will not connect to the WiFi
Re: No internet or sky
@MariaG100
The first thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
If this is of no help give Sky a call to report it to them.
@MariaG100
At that time of night it could be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep.
If it's not back by 0700 use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
▪️I AM NOT A SKY EMPLOYEE ▪️
