Discussion topic: No internet light
Message posted on 06 Jul 2024 08:25 PM
No internet light
My broadband has decided to stop working. The internet light is off and the voice light is orange. Have tried everything suggested on the website and nothing is working. Sky customer service is useless.
can someone help?
Message posted on 06 Jul 2024 08:59 PM
Re: No internet light
If you run the service checker in mysky app using mobile it should let you book an engineer if it detects an external fault
Message posted on 06 Jul 2024 09:05 PM
Hi, says that there's a problem with the broadband. It then does a 'test' and then can't find a fault yet there's no internet light on.
Message posted on 06 Jul 2024 09:08 PM
Where abouts are you ?
Uk
Message posted on 06 Jul 2024 09:09 PM
First half of your postcode if thats ok with you
Message posted on 06 Jul 2024 09:14 PM
Yes okay it is sg12
Message posted on 06 Jul 2024 09:22 PM
Can't find anything major in that area.
Either give sky a call first thing tomorrow or drop us a note here if its not back on tomorrow. Unfortunately skys lines are probably closed now
Message posted on 06 Jul 2024 09:23 PM
Yeah I'm going to try to speak to someone tomorrow. Unfortunately this isn't the first time I've had issues with the broadband connection and I've only been with them since march
Message posted on 06 Jul 2024 09:28 PM
Contact sky as below
Follow the link and choose need more help
https://www.sky.com/help/home/
If in the Republic of Ireland go to the bottom of the page and change the flag to Republic of Ireland
Lines should be open from 08:00
