Discussion topic: No internet light on hub
Message posted on 23 Feb 2026 09:32 AM
Power light green
No internet light at all
Wifi light green
Voice button orange
Unplugged everything and turned off and keeps happening. Unabale to connected to wifi
Message posted on 23 Feb 2026 10:14 AM - last edited: 23 Feb 2026 10:14 AM
Re: No internet light on hub
@Amy21488 That will be correct from what you have posted, so try the link below but later after about an hours time from when your no light came on for the Internet one!
If you haven’t done it already use the below link to check to see if there are any broadband problems or outages nearby if enough time has passed for a fault condition to be displayed by the software test! This should determine if there's an identified fault affecting multiple households.
