Discussion topic: No internet for days.
Message posted on 12 Sep 2024 12:41 PM
No internet fordays but of cpurse they are still taking ny money. How the hell do I contact sky directly? Im just going to cancel it alltogether if it isnt sorted today. Ridiculous!
Message posted on 12 Sep 2024 12:50 PM
Re: No internet for days.
@Gary085 Can you please run the service checker, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
After the service checker completes and if it comes back green all good can you click on broadband to run an updated test please. If you get amber or red please follow the on screen instructions.
Message posted on 12 Sep 2024 12:52 PM
Billing continues during a fault or outage. The below link explains the Ofcom agreed auto compensation scheme which Sky operates for when there is a TOTAL loss of Sky Broadband or Sky Talk.
https://www.sky.com/help/articles/auto-compensation
If you have a total loss of service and it isn’t fixed after two full WORKING days from when you notify Sky of the fault, you will become eligible for it. It’s applied 30 days after the fault has been repaired and will come in the form of a credit appearing on your Sky account (new rates apply from 01/04/24 of £9.76 per day).
Dial 150 from your Sky Talk landline or a Sky mobile alternatively you can use:
https://www.sky.com/help/home
UK customers: Scroll down and click on ‘Need more help’ and it provides a 0333 number.
ROI customers: change the flag in the bottom right corner of the link to the ROI flag then scroll down and click on ‘Need more help’ and it provides a 0818 number.
(The forum doesn’t allow us to type the numbers in full).
You will find that similar to calling other large companies the start will be automated which may also try to send you here to the forum. Stay on the line as long as possible and don’t hang up. If necessary say nothing when the automated system asks you what your call is about as it should then route your call into a queue for the next available agent.
If Sky aren't already aware it's unrealistic to expect a fix the same day. Openreach normally quote two working days for most fixes depending on where/what the fault is. If you cancel you need to give 14 days notice by which time it would almost certainly be back.
Message posted on 12 Sep 2024 01:07 PM
The service checker says everything is fine, but it isnt
