2
This discussion topic has been answered Discussion topic: No internet connection
This message was authored by: Liam88888
I have no internet connection.
Power is green
internet nothing
WiFi green
voice amber
any suggestions?
I've turned it off at the wall and reset it and still the same thing happens
Re: No internet connection
@Liam88888
Start by using this link to check if there are any broadband issues locally that may identify a known fault which could be affecting multiple households ~
(this won’t necessarily identify a fault just affecting your address).
🔸Various hub lights; This link provides information about the coloured lights you may see on the various hubs
🔸Red light on ONT?; See this link ~
🔸Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky allow customers working from home to use it, they won’t receive additional or quicker support.
@Liam88888
This message was authored by: Me134
Power is green
internet nothing
WiFi green
voice amber
any suggestions?
Try the following,  you can also use the MySky app.
To check on local outages.
To run the local checker.
https://www.sky.com/help/articles/broadband-diagnostic-start (do run all tests)
Not a Sky employee
Sky FTTP 500Mb to Max Hub
