Discussion topic: No internet connection
Message posted on 16 Aug 2026 12:11 PM
Can't get internet connection
Message posted on 16 Aug 2026 12:14 PM
Re: No internet connection
@WilliePaterson
Start by using this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
🔸Various hub lights; This link provides information about the coloured lights you may see on the various hubs
🔸Red light on ONT?; See this link ~
🔸Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky allow customers working from home to use it, they won’t receive additional or quicker support.
Message posted on 16 Aug 2026 12:16 PM
Are you in Scotland ?
