Discussion topic: Ethernet Cable for Sky Hub
Message posted on 16 Aug 2026 10:14 AM
Hi I have a Sky Hub router ( the white box one with the light in the middle) I'm looking at wire connecting it to my smart TV (due to limited sockets and only one BT socket I'm unable to move it far away and WiFi connection is causing interference to the picture .) Which Cat number should I be using ? Plz thx
Message posted on 16 Aug 2026 10:24 AM
Re: Ethernet Cable for Sky Hub
Cat 5e or Cat 6 will be fine. Theoretically, it should be good at 1000Mb/s for up to 100m.
I doubt you can still buy it, but the old Cat 5 was only capable of 100Mb/s. Make sure it is 5e and avoid anything labelled as CCA (copper clad aluminium). It's rubbish.
Message posted on 16 Aug 2026 11:56 AM
Great thank you - I have a cat 5e in my hand so I'm going to go with it !
Message posted on 16 Aug 2026 12:13 PM
@Wallinl You say you want to connect the TV. Just so you are aware, even today TVs only usually have a 100Mb/s network card, (they don't need much bandwidth), so don't be surprised if it only reports a 100Mb/s connection instead of a gigabit one. 5e or 6 is still the best thing to use, though.
