Discussion topic: No internet connection
Message posted on 20 Jul 2026 11:53 PM
Hello, for the past few days we have been experiencing some issues with our broadband/wifi, the orange light show then goes after some time. We have ran several diagnostics but keeps saying everything looks good when it's not the case, none of our devices work via our broadband and WiFi, we have restarted several times and reset but still facing the same issue. This is affecting all our work and needs to be sorted urgently!
Message posted on 21 Jul 2026 12:43 AM
Re: No internet connection
I am having the same issues and it's not the first time within 2-3 weeks.
Message posted on 21 Jul 2026 04:50 AM
@SamandJay
Start by using this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
If you’re still having problems you may need to report it to Sky. The easiest way is to dial 150 free from your Sky Talk landline (if it’s still working).
Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky allow customers working from home to use it, they won’t receive additional or quicker support.
@Mari_M
When there are broadband issues between midnight and 7am it could be essential overnight maintenance taking place. It is carried out at those times to minimise disruption and there is no advance warning provided.
See this pinned post at the top of the Broadband board from Sky which could be relevant any night this happens…
https://helpforum.sky.com/t5/Broadband/Important-Notice-Scheduled-Broadband-Maintenance/td-p/5151847...
If you have an ONT box displaying a red light, see this further advice…
Hopefully it’s back up and running before 7am. If it’s not, try restarting your hub or post back in this thread and we can try to offer additional advice.
