Discussion topic: No internet connection
This message was authored by: Simoody66
Hub shows WiFi connected but internet is not connected (light is orange)
reset and still not working - happening on a daily basis for the last week or so
Re: No internet connection
@Simoody66
The first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
