Discussion topic: No internet connection
Message posted on 03 May 2026 10:35 AM
Internet light is flashing orange and will not connect
Message posted on 03 May 2026 11:02 AM
Re: No internet connection
@Tracy203
If you have a broadband issue the first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
