Discussion topic: Connection
Message posted on 03 May 2026 11:02 AM
Connection
There is a connection issue recognised in your broadband
Message posted on 03 May 2026 11:04 AM
Re: Connection
@Deepa4
If you have a broadband issue the first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
