1
This discussion topic has been answered Discussion topic: No internet connection
This message was authored by: Lee662
Hi, my internet suddenly stopped working today. I think the issue is with the hub / internet router as the light has gone off and won't come back on.
Re: No internet connection
@Lee662
If you have a broadband issue the first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
@Lee662
