Discussion topic: No internet connection
This message was authored by: Casey55
No internet connection today. All lights on router. Done the usual turn off on. Checked signal online through my phone data which say ok but can't do it through my sky broadband as it says no connection. Lost connection on all devices and its only light use maybe 2 phones browsing and tv Netflix at one time. Area WF15.
Re: No internet connection
@Casey55
Use this link to check to see if there are any broadband issues or outages nearby (even if you’ve already tried it ~ it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps retry later).
