Discussion topic: No internet connection
Message posted on 05 Oct 2025 03:32 PM
System checker says everything is good but I keep losing internet connection
Message posted on 05 Oct 2025 03:38 PM
Re: No internet connection
Your duplicate thread has been removed.
Use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour later).
