Discussion topic: No internet connection
This message was authored by: LauraS3
My set up has not change I have a solid amber light on internet
Re: No internet connection
@LauraS3
Use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update).
