Discussion topic: No internet connection
Message posted on 11 Aug 2025 11:54 AM
Hi,
This morning everything was running smoothly untill about half hour ago.
I have no Internet my hub is showing lights in this order,
Green
Orange
Green
Orange.
I have done a reboot and reset but nothing seems to be working.
Tried everything that was on the page but still the same
Message posted on 11 Aug 2025 12:12 PM
Re: No internet connection
@Lozz30
If your broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
