Discussion topic: No internet connection
Message posted on 07 May 2025 01:25 AM
I've got no internet connection. I've got 2 orange lights & I have restarted my roster twice. What's going on
Message posted on 07 May 2025 02:49 AM
Re: No internet connection
At that time of night it could be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep.
If it doesn't return by 0700 use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
