Discussion topic: No WiFi
Message posted on 07 May 2025 12:57 AM
No WiFi
The light in the middle is orange I have no WiFi
Message posted on 07 May 2025 02:52 AM
Re: No WiFi
At that time of night it could be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep.
If it doesn't return by 0700 use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
