Discussion topic: No internet connection
Message posted on 11 Apr 2025 06:32 PM
It says there is a connection to the broadband router but no internet connection. Tried all trouble shooting and service checker says no issue
Message posted on 11 Apr 2025 07:07 PM
Re: No internet connection
@Boredpurplegirl
This should determine if there's an identified fault affecting multiple households.
