Discussion topic: No internet connection
This message was authored by: Patricia0204
Internet not connected to router even though you are saying everything is fine
Re: No internet connection
@Patricia0204
This should determine if there's an identified fault affecting multiple households.
This message was authored by: Tichy
Every night my internet keeps going all fuzzy and goes on and off
I want someone to call me
@Tichy
If you’re not already aware this is a customer helps customer forum and you aren’t contacting Sky Customer Services. No,one will call you.
