Discussion topic: No internet connection
Message posted on 26 Jan 2025 11:03 AM
Hello,
I dont have any internet connection and its been like this since 24th Jan.
Message posted on 26 Jan 2025 11:05 AM
Re: No internet connection
@ZeliaFreitas
The lines may be busier due to the damage and disruption caused by Storm Éowyn.
