Discussion topic: No internet connection
This message was authored by: ACR7
My Sky glass just stopped working about  an hour ago. I have restarted the tv and router but still no internet connection. Tried doing to test and fix online and still nothing. Can someone help please.
Re: No internet connection
@ACR7
