Discussion topic: No internet connection
Message posted on 07 Oct 2024 10:15 AM
I have 2 green lights on the modem but the middle light is not even orange, just off, hence no Internet connection. I turned it off and on again several times but, it's made difference.
Message posted on 07 Oct 2024 10:20 AM
Re: No internet connection
@Kevin19561 Can you please run the service checker, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
After the service checker completes and if it comes back green all good can you click on broadband to run an updated test please. If you get amber or red please follow the on screen instructions.
Message posted on 07 Oct 2024 10:34 AM
I run the service checker and broadband checker, they both say my service is fine but still no green Internet light.
Message posted on 07 Oct 2024 10:35 AM
@Kevin19561 How long has your broadband been down? Is it less than 1 hour or more?
Message posted on 07 Oct 2024 10:45 AM
It's was operating intermittently until about an hour ago when it stopped working at all.
Message posted on 07 Oct 2024 11:39 AM
@Kevin19561 After you ran the service checker did you click on broadband to run the further test?
Message posted on 07 Oct 2024 11:49 AM
I did run broadband checker, it still said my service was fine. Thankfully my Internet connection is now working, it returned about 15 minutes ago. Thank you for you're time trying to help me.
