Discussion topic: No internet connection
This message was authored by JakeGunning This message was authored by: JakeGunning
There is no internet connection and no visible problem. All lights are green, connection checks appear to be okay yet there is no internet connection.
This message was authored by mae-3 This message was authored by: mae-3
Re: No internet connection
@JakeGunning
Recommend a disconnect and reconnect the internet via the broadband router interface or leave the router off for an hour to establish a new internet zone.
Zen internet on FTTP (900Mbps down, 100Mbps up). SAT> IP (Apple 4K 2nd gen TV to LG C1 OLED UHD TV/Dolby Atmos Denon AVR, DacMagic Plus for Hi-Res audio), hosting own blog/forum (cluster), OPNsense & Zenarmor L4/L7 NGFW & DPI IDS/IPS, Asus ET12 Pro Tri-Band wifi, Linux, Gamer: Xbox Series X/i7 laptop, round-robin DNS over HTTPS, non-proprietary VoIP HD AMR-WB (G.722.2) and more... Beta tester Apple iOS/watchOS/tvOS/iPadOS/macOS. Dr Mae-03 PhD.
JakeGunning
Unfortunately this did not work.
all broadband and WiFi checks come out with no apparent issue.
when I connect to the WiFi with my phone it says "no internet connection".
@JakeGunning
Suggest contacting Sky and I recommend this goes to PM with Sky.
