Discussion topic: No internet connection on tv
This message was authored by: Kirstymarie04
Sky tv wont connect to our broabdand,  no interent connection at all.
Everytime i do a broadband check it says everything is ok??
can you check this please
Re: No internet connection on tv
@Kirstymarie04 you are not talking to Sky by pisting in the forum but you can check this yourself as if you have Sky broadband you can run a conection test in the My Sky app which can go on to check connection to your devices. At a guess it could simply be the TV is not getting a strong enough wifi signal so you may need a booster or even usecan ethernet cable instead. If younpkan to stream video you need a good wifi signal which is why using a cable is more reliable.
This message was authored by: blushbaby6898
I am in Newcastle under Lyme and no internet since yesterday..
