Discussion topic: No internet connection but reported ok
Message posted on 31 Oct 2025 12:49 PM
My Internet connection is dropping regularly this morning an now into the afternoon but your checks say that there are no problems in my area. How can this be?
Message posted on 31 Oct 2025 12:55 PM
Re: No internet connection but reported ok
@ianutt
You aren’t communicating with Sky by posting on here. This is a customer ➡️ customer discussion forum where we try to help other Sky customers.
If you haven’t done it yet you can use this link to check to see if there are any broadband issues or outages nearby.
Note: It doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps retry later.
