Discussion topic: No internet connect
Message posted on 08 Jul 2026 02:55 PM
No internet connect
No WiFi, ran all the tests and came back fine but no internet 🤷♀️ anyone else in same boat?
Message posted on 08 Jul 2026 03:00 PM
Re: No internet connect
@Sambutton11
Sky has nearly 7 million broadband customers so at any one time quite a few will have issues.
Use this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky accept it's fine for customers working from home to use it, they won’t receive additional or quicker support.
Message posted on 08 Jul 2026 04:29 PM
I have and have completed all the advice by the lovely @Daniel0210 Hiwever all seemed good as I went through the checks. I called Sky customer services from my Vodafone mobile and the lady was incredible. Well are up and running again! Well done Sky! 👏👏👏👏👏
