Discussion topic: No internet at home
This message was authored by: Stef26
No internet at home
I've got 2 green light but middle light is orange woke up with no WiFi
Re: No internet at home
@Stef26
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps try it again later).
