Discussion topic: My WiFi is not working
This message was authored by: helen+gunn
No WiFi connection can't use Internet do cant watch any telly as I have a sky puk box
Re: My WiFi is not working
@helen+gunn
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps try it again later).
@helen+gunn
The first thing to check is this link to see if there are any outages in your area, it can be a bit slow at picking up issues so if nothing shows perhaps try it again later:
If there isn't try running the line test here:
If this is of no help give Sky a call to report it to them.
