Discussion topic: No internet again
This message was authored by: Sammie31
No internet again
Openreach came out to fix this problem on Monday said it had been turned off at the cab he turned it back on and all was fine until now when the broadband is not working again and I have a green light for power then amber for internet then next light green and voice light amber ... I have reset router but has made no difference at all
Re: No internet again
@Sammie31
Likely unconnected to your previous issue. When there are broadband issues between midnight and 7am it's quite possibly going to be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep. You don't receive advance notification of this from Sky or Openreach.
Hopefully it'll be back up and running before 7am.
