Discussion topic: No internet Connection
This message was authored by: Marinela-
My internet is not working, as I restart the router but it's showing a red light at the voice
Re: No internet Connection
@Marinela-
When there are issues between midnight and 7am it's quite possibly going to be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep. Hopefully it'll be back before 7.
If it's not use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour or so later).
