Discussion topic: No connection
Message posted on 04 Nov 2025 10:36 PM
No connection
My network says it is connected however it then says disconnected I have turned everything off and on and still nothing
Message posted on 05 Nov 2025 02:51 AM
Re: No connection
@Poppie25
Use this link to check to see if there are any broadband issues or outages nearby (even if you’ve already tried it)
Note: It doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps retry later.
