Discussion topic: No connection
Message posted on 03 May 2025 12:02 PM
No connection
WiFi completely down in Luton
Message posted on 03 May 2025 12:17 PM
Re: No connection
@Kyrenwillis
If you haven’t done it already use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
