Discussion topic: sky has dropped out in E17
This message was authored by: E17_1
Two days in a row sky has dropped out but the app says everything is fine.
Re: sky has dropped out in E17
@E17_1
If you haven’t done it already use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
