Discussion topic: No connection to Internet
Message posted on 05 Jul 2025 06:53 PM
Last night you changed Internet speed now I have no Internet
Message posted on 05 Jul 2025 07:29 PM
Re: No connection to Internet
As this is a customer helps customer forum then nobody here changed anything.
The first thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
If this is of no help give Sky a call to report it to them.
Message posted on 05 Jul 2025 07:42 PM
@Robert181 Did you have a requested speed upgrade, that is a call to sky for you and time is getting short if you want it checked by this evening!
Message posted on 06 Jul 2025 12:56 PM
They downgrade the speed as i complained about the price d they put on cheaper rate slower speed and now no Internet at all worked for i hour great to nothing
Message posted on 06 Jul 2025 01:09 PM
@Robert181 You do not say what you had then to what you have now, and if sky did change it all, may be worth switching everything off for 10 minutes and starting from there.
