Discussion topic: No broadbsn
Message posted on 11 Jul 2026 11:23 AM
No broadbsn
My broadband has been playing up and kept cutting out last week now it's stopped working altogether there are 2 orange lights and two green lights. This happened back in March and an engineer was sent out to fix it. I neec internet for my work. I am now considering changing from sky as you cannot provide fibre broadband either. I also have issues with the satellite connection as I don't seem to be able to pick up signal on most channels.
Message posted on 11 Jul 2026 11:41 AM
Re: No broadbsn
You'd be better off posting separately about the satellite signal issue as this board is for broadband issues.
The extremely hot weather won’t be helping but use this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky accept it's fine for customers working from home to use it, they won’t receive additional or quicker support.
Message posted on 11 Jul 2026 11:47 AM
Re: No broadbsn
I have had this problem before I have just checked everything and there doesn't seem to be any problems else where. I would like this sorting please. I have not phone line either as that is on the broadband line as well.
Message posted on 11 Jul 2026 11:52 AM
Re: No broadbsn
It has just started to work again I'll keep an eye on it now
