Discussion topic: No broadband
Message posted on 01 Oct 2026 06:20 PM
No broadband
I have no internet connection at all?? Is there a issue ??
Message posted on 01 Oct 2026 06:23 PM
Re: No broadband
@Saj_77
Start by using this link to check if there are any broadband issues locally that may identify a known fault which could be affecting multiple households ~
(this won’t necessarily identify a fault that just affects your address).
If you’re still having problems you may need to report it to Sky. The easiest way is to dial 150 free from your Sky Talk landline (if it’s still working).
🔸Various hub lights; This link provides information about the coloured lights you may see on the various hubs
🔸Red light on ONT?; See this link ~
🔸Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky allow customers working from home to use it, they won’t receive additional or quicker support.
Message posted on 01 Oct 2026 06:45 PM
Re: No broadband
Yes I have no internet
Message posted on 01 Oct 2026 06:47 PM
Re: No broadband
@Chlobol21
If you are new to the forum then welcome to the Community, which is predominantly made up of Sky customers helping other Sky customers. You aren’t talking to Sky by posting here.
See my post immediately above yours.
