Discussion topic: No broadband
This message was authored by: Russ40
No broadband
Hi, our broadband/wi-fi went down last night and it's is still down this morning.
we have been unable to watch any apps, watch separate sky boxes and work from home.
i have tried to reconnect several times without success, I have turned all boxes, router off etc with nothing!!
I would appreciate a call back to fix this issue.
thanks
Re: No broadband
@Russ40
Welcome to the Community.
No one will/can call you back. You haven’t contacted Sky by posting here. This is a customer ▶️ customer discussion forum where we try to assist other customers.
The first thing to do (even if you’ve already tried it), is use this link to check if there are any broadband outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
Working from home?; Sky broadband discussed on here is a domestic service and whilst it's fine for customers working from home to use it, they won’t receive additional or quicker support.
