Discussion topic: No broadband
Message posted on 08 May 2026 02:33 PM
No broadband
I'm not at home. But my partner needs broadband to work from home and it's not working
Message posted on 08 May 2026 02:36 PM
Re: No broadband
Hi. Anyone there
Message posted on 08 May 2026 02:37 PM - last edited: 08 May 2026 02:39 PM
Re: No broadband
@James573
Posting again within 3 minutes due to no one replying is a bit unrealistic. Working from home does not mean a quicker response.
If you have a broadband issue the first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
