Discussion topic: No broadband
This message was authored by: BarryHurley
No broadband
Hi I have no internet on my laptop. Please send an engineer out.
Re: No broadband
@BarryHurley
This is a customer ▶️ customer discussion forum where we try to help other customers. You haven’t actually contacted Sky by posting on here. Therefore no one knows who you are or where you live.
If you have a broadband issue the first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
