Discussion topic: No broadband
Message posted on 01 Feb 2026 04:53 PM
No broadband
Message posted on 01 Feb 2026 05:11 PM - last edited: 01 Feb 2026 05:13 PM
Re: No broadband
@rsttz Put simply it's got nothing to do with sky and they have no pull in getting it done for you, in any way shape or form, yes the Engineer doing the job was wrong waiting for the Fibre to be up working before the copper removal, but the Forum has zero idea as to why the Engineer decided to do what he did and the reason or the method behind that fact!
Some installations do go wrong, and although some can be fixed fairly quickly others can be very long protracted drawn out affairs, the Forum nor Sky will have any insight into that reason....
Now because you say the copper was pulled going with this was OR Openreach primary on the job, if another or another contractor did that who knows. You can only pursue this with sky as you are there customer, nothing else!
Message posted on 03 Feb 2026 11:46 AM
Re: No broadband
Im the same since 2nd Jan go live date we only have sky tv getting connection every other device will connect to wifi but with no internet connection we have paid out so much in 5 lots of mobile data its unreal
