Discussion topic: No broadband
Message posted on 08 Nov 2025 12:36 PM
No broadband
No broadband since 8.00 this morning app says no problems detected but got an amber light on router after rebooting 3 times.
Message posted on 08 Nov 2025 12:38 PM
Re: No broadband
@abbafather+01
Use this link to check to see if there are any broadband issues or outages nearby (even if you’ve already tried it ~ it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps retry later).
Message posted on 08 Nov 2025 12:45 PM
Re: No broadband
Thanks but that didn't work either.
